GriffinRU
04.18.2006, 10:12 PM
Originally Posted by cspurlock
"and how is that different?" not sure what you meant by that?
I understand how kv ratings work, I'm just saying that the person I know said don't compare our 4400kv listed to that of other common brands like Hacker because they are testing it a differnt way. He said the acutal kv on that motor would be less if it was tested the same way everyone else was tested. I have the motor, and no way it is 4400kv. I would guess between 2500-3000 is more accurate.
Why Bother- That meant why would you buy an HV system and buy an aveox motor to replace the novak motor, it just doesn't make sense to me. You would be so deep dollar wise, and still not have that great of a setup. Why not just buy something else.
Guessing is not a precision tool. And just because it doesn't get to its rated RPM in emaxx (very well known reasons), doesn't mean that it doesn't have Kv=4400. So, until you have proven data which shows that Novak's info incorrect, I will stay with Novak's data. Motor is motor and it doesn't need to be Hacker brand or like to agree with theory of operation and physics, if you wish.
Dollar wise everything is possible and e-bay is not a bad place. Soon you can get sensored motors from Feigao as well. So $250 HV-Maxx plus $60-90 Feigao (S/L/XL) Motor...
Artur
P.S. Personally, I think HV-system was designed by two different teams. While Team responsible for ESC did amazing job, motor group screw them up big, forcing them even create last minute fixes in program to make somehow system operational at all. Too bad nobody will tell you the real story... :)
