04.20.2006, 10:34 AM
Hi,
Indeed I am using mechanical brake because I had bad experience with brake fade on the BK9920. Also, I can't get my mind round the fact that with the esc brake, only the the centre spur is stopped but the front/rear drive shaft is still free to move.
I run my BK 9920 in forward only mode to conserve the esc a little as I live in a tropical country where heat is an issue. Like crazyjr said, I am using the third channel of my radio with program mixing to activate the brake servo.
Regards,
Joe Ling
