crazyjr
crazyjr's Avatar
04.21.2006, 02:53 PM
Well its a little late on the results, but it works so farthe only thing i need now are batteries that won't fall out(using stick packs for now) but i wheelied and braked hard tring to make it come loose and so far it hasn't
A little tip for anybody running the HV W/fan with the Gorilla mount. The stock kit hex bolts will work, but you only get a few threads in before tightening. I found a screw that works, Traxxas part number TRA2556 header screws are long enough and correct thread and come 6 to a pack so you have spares
Combatcm: I don't know. i'm sure the rod could work but not sure how adhesives will affect the rod. Maybe somebody with CF experience can provide some input
