04.21.2006, 07:29 PM
yea, it uses the standard type scew. not sure but i think its a 4-40. length is up to you since they come in so many lengths as well as many people use locknuts on the other side. thats why it doesnt come with any. also, yes, it goes, plate, disk, bearing, slipper w/pads, disk and the the hex plate. followed by a spring and then a locknut. you may have to file the edges for the bearing to fit. im not sre though. i had to when i got the rrp slipper and then i got the strobe so im not sure. as far as how tight, its up to you but i would go as tight as possible (within reason of course) and then back a 1/16 or so off of it.
EDIT: im not sure if sylevester has one or not but mine didnt as well as strobes website says it doesnt come with them...
