03.28.2005, 10:25 PM
Welcome aboard, Gallagher! Good eye, by the way. This could partially explain the heat, but if the diffs are swapped, the motor would spin correctly (not sure if this is or isn't the case). It is certainly something to look for. The ever decreasing performance could indicate another problem, though (seems to be getting worse each time).
