Lithium Battery Q's
Mister_Anderson
Mister_Anderson's Avatar
Lithium Battery Q's - 04.22.2006, 04:53 PM
I own a Rustler with the Scorpion 3200 Li-po system (battery and charger) and in a bad crash I put a hole in the plastic housing on one of the cells :035: . I examined the cell and the area with the damage smells like denatured alcohol. Is that the electrolyte? If so how do I dispose of the pack? It has almost a full charge. I was thinking about getting the Peak Racing 4800 Li-po. I can purchase an adapter from fmadirect.com to charge the battery, but I don't want to spend the $170 if I don't have to.
I am very interested in Li-Ion batteries because they look a lot tougher, with M1 can charge in 5 mins (that's 4 times faster than the best time with the scorpion), and are safer. Now what I need to know is will the charger I have work? If not which charger and battery combo would you recommend? (Preferably with M1 tech.) Do the cells need a balancer like Li-Po's?
Also, if i were to purchase the Makita 18v would I have enough cells to make two 3s2p packs? If wrong please correct me. How would I configure these cells? I know how to do series, but how would I incorporate the other cells for parallel? I am completely lost on that wiring.
Thanks,
Chris
A.K.A. Rusty Boy
E-Rusty:
Mamba Max ESC
5700kv Motor
RCM-RC Chassis
A123 Racing 2300 MaH 2s1p Series
16/84
Top Speed M.P.H. ~45.
"Profit Is Not a Four Letter Word, But Rape Is Illegal."
