03.29.2005, 02:13 PM
Right now your BEC is in your EVX so you dont need a receiver pack. I would say go with a BEC. I dont like the idea of having to worry about a extra pack.
The main difference between the 8L and 9L is the number of cells that you will be running. You may get a slightly longer runtime with the 8L on 12 cells and slighty more power with the 9L on 14 cells. If all of your current packs are 6 cells and you plan on staying with them get the 8L. I went with the 9L because before I was brushless all my packs were 7 cells.
You dont need to have the G2 motor mount but its recomenned.
