sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 01:50 PM
here is a alternative for you......till you can get a UBEC....goto radio shack and pick up a 4 cell AA holder and solder a servo plug to the end of it......red/red & black/black and then remove the extra wire....out of plug....then plug it into the slot on the receiver...labeled batt......make sure the black wire is the same way as your servo wires.......pick up some 3mm screws from a hardware store and you could be up and running in a half hour or so....just a thought for ya...
  Send a message via MSN to sjcrss
