sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 07:17 PM
no doubt....it says....one plug is a charge jack...which looks to be the red square plug...the other red plug goes into the reciever..and the black one goes to the battery.........just hardwire the batt in place of the black plug and you should be good to go....open up the switch housing to make sure the red square plug is for charging....but I'm 99% sure it is.........did you find some 3mm screws for the strobe slipper yet?.....also by any chance do you have msn instant messanger or aim.....then I can walk you thru everything easier
  Send a message via MSN to sjcrss
