Thread: Strobe slipper
Stobe slipper tip
rchippie
rchippie's Avatar
Stobe slipper tip - 04.24.2006, 08:31 PM
This is a tip for anyone using the strobe slipper. If you look at your (BLACK) diff ring mounting plate you will notice there is a reasesed section on each ring plate. This allows your bearing to slide back & fourth after some time. Simply put a few shims on each side of your slipper, enough to fill up th reasesed section. This keeps you bearing centered in your slipper & helps keep your slipper from wobbleing. This directions are on the strobe site. I just wanted to make sure everyone knows this tip.
REAL MEN RUN BRUSHLESS
