sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 10:14 PM
try putting in the BEC jumper...when you program it.....the controller is designed to be setup with the bec jumper in.....when i program mine....I unplug my short servo lead ext. ( it has the red wire missing on the end that plugs into the rec.) and plug the controller directly into the rec....then i go thru the programming process...and once finished I remove the servo wire from the rec...and plug it back into my servo lead ext...with the missing red wire ..and that goes back into the rec...and I'm good to go...
  Send a message via MSN to sjcrss
