Jasper
04.26.2006, 08:26 AM
Question 1:
The 8XL is a good choice. I had a 7XL in my savage. I liked the speed, but the runtime was for me to short. 5-10 minutes. With GP3300 cells (wich I used one season for serious racing) So the runtime must be good with better cells.
Question 2
I used the mechinical brakes on my savage. The controller can be set with only forward driving.
Question 3
If you mount the battery cups under the mechinical brake. It can be done. I also should recommed that because of the lower cg.
Question 4
You can also make an motormount at yourself. I used 8mm aluminium. I cutted the plate in the right sizes. I drilled some holes for putting in the motor. At the left and right I drilled 3mm holes. I tapped screw thread in these m3 holes. I drilled one hole at each TVP for mounting the motormount.
Name:	6mm motormount 005.jpg
ID:	1105   Click image for larger version
Name:	6mm motormount 019.jpg
ID:	1106   Click image for larger version
Name:	6mm motormount 023.jpg
