skellyo
skellyo's Avatar
04.27.2006, 12:49 PM
Originally Posted by furryninjas
and has anyone ever ran offset rims in rear to make it wider? would this make it handle better or just run the standard offset on front, and inset on rear to make it even?
I run the standard width FLM arms on my Pede, but upgraded the front with nitro pede spindles, carriers and flm caster blocks. I also use maximizer Stampede to Maxx wheel adapters and run RPM Stablemaxx wheels for a wider stance. This pic gives you a good idea of how wide it is with these parts (keep in mind this is the FLM Ext chassis as well):
http://onelouds10.com/flm_pede4.jpg
