Originally Posted by Thunderbruiser
that was a cool little vid man is that t-maxx running an rb323? it seems like it's got some kick...
It's the Sirio .23, -which is basically the same engine. It has an RB 086 pipe and is geared 20/72. Yeah, it does have some serious power. I finally got the drivetrain to the point where I can go and run several tanks of fuel before I grenade something. Thanks for the compliments on the video, -I never would have imagined that anyone from this forum would have found it, but the internet makes it a much smaller world.
and James running 12 cells you have ot also account for the sus. it'll be a little softer with the extra weight...if you save up and get 3s lipo pack it should give you around the same performance as 12 cells with less weight...though i am not 100% sure cause i am new to the lipo and bl scene
Yeah, my 3S gives his 12 cell rig a good run for his money, but it falls just a little bit short. Some more gear, and I could easily pull him with my 9920 controller, -but it would get hot. Geared the way it is right now (20/87), the power meter shows max current at around 90 amps, -so I'm already knockin' on the door of being "done", -at least with a 3S. I have the advantage on overall weight, -his rig is heavy, -which does make it more stable at the higher speeds.
