furryninjas
04.27.2006, 10:49 PM
ok, so i had to mount it through top of chassis instead of bottom to clear the braces, and then i had to turn it around so the wires were coming out the front instead of towards the rear........ but now it turn correctly anyways.... but now, when the shocks compress the wheels toe in real bad, is this normal???
its late so ill try to get picks tomarrow.....
oh shit, little driving in yard, no longer than 5 minutes, no jumps or anything......(stock brushed motor, low battery), the little C-clip popped off the shock shaft above piston, and its too low in shock cylinder that i can't snap it back on..... GPM shocks SUCK!!!! does seem like there's enough space between 2 C-clips for the piston to fit, i think that may be why i came off so easily.... WTF!!!!:mad:1
maybe shocks from another car will fit?
