04.28.2006, 12:31 PM
Can I use the "bash pack" (4200 mah, stick pack, $35.00 each, or would side by side packs be better? How many volts do these packs really produce under load? Would it be safe to use 36 of these cells (6 6 cell packs) on the BK 36150 with the 2250 13 turn, or is that risking electronic death? How does charging at different amps settings affect the batteries? How good are the integy 4200 mah packs, and the 4200 mah packs from other manufacturers?
