MetalMan
MetalMan's Avatar
04.28.2006, 04:44 PM
Only 26-30mph?!? With that motor and those batteries, you'd have no problem getting to 45mph+ (assuming the 9920 can handle it). If you don't want those speeds on the track, you could dial down the EPA or just use a light throttle finger. You may even run into overheating issues with the motor not having enough of a load!
