Tom F
RC-Monster on a Budget
04.29.2006, 04:46 PM
It's easy to build the packs, it's cheaper, and you can build them in whatever funny shapes you want :)
Serum - where did you get those cells?!
If you're running huge currents then i would imagine you want some big LiPo or LiMn cells. Apogee are selling 3S packs 3800mah 20C packs - thats 76Amps.
If you ran 4 of those, you'd have nearly 3.5Kw of power to play with...
I was speaking to the guy and he said the average loaded voltage is 3.8 and they have a lower internal resistance so run cooler and the voltage doesn't drop as much under load...perhps you should think about using those?
Sounds like a great project - good luck.
http://img513.imageshack.us/img513/3880/dscn1559dp5.jpg
Brushless - How fast do you wanna go today?
  Send a message via MSN to Tom F
