04.30.2006, 04:58 PM
The Dominator is just a center slipper and aren't really anything special. There was a direct replacement for the Dominators (came on another truck) that was an actual diff. That would be the way to go but in that case you can use any diff. I would go for a ofna diff and a ofna 51 tooth plastic spur so a hardened pinion isn't necessary. With the diff a slipper isnt really necessary. If you do deside to go with the tranny just leave the brakes hooked up as it were nitro and set the esc to forward only without brakes. That will allow you to use the mechanical brakes. There is something with the throttle mixing on the radio that is anther option but im not exactly clear on what that does.
