cabking
05.01.2006, 06:28 PM
Originally Posted by MacII
Can't answer the Spektrum questions, they are a bit off the main subject of how best to wire in an On/Off, so far on the BEC is the only suggestion, any other ideas?
I think the Spektrum is at the heart of this problem.
As far as I know a switch on the BEC side is your only option, unless you can get some 100amp plus switches for the main power.....not very practical :002:
I too have had this problem ONLY with the 2.4ghz and stangley ONLY with the 9920 and not the 18.97. Fitting the switch to the BEC fixed the problem.
