Big Daddy
05.03.2006, 11:51 PM
IT IS ALIVE!!!!!!!!!!!!!!!!!!!! *maniacal and evil laughter*
Well I couldn't decide which system exactly to get for the truck so I took the 10l/9918 out of my savage and hooked it all up today. I got two quick runs in before it was just too dark.
After adjusting the spacing between the pinion gear and spur to get rid of the sparking (yikes) It straight hauls. I had a hard time seeing it as it passed lighted and unlighted areas in the street. I was running it on 14 GP3300 they were not fully charged because I used them about half way last time I ran my savage.
It is the stock gearing and I believe a 12 tooth pinion, it's been awhile I will have to count teeth to make sure. The motor got a little hot at the end of the run but I could still hold the motor in my hand for about 5 to 7 seconds before it got HOT. I will probably work on the gearing some this weekend to see what I can do with it.
It doesn't wheelie off the line but it will spin the tires like it's nothing. The handling of the hellfire is unbelievable. It is the most responsive truck I have driven. I will have to try and get some pictures posted later tomorrow after work. If I can still use my old hosting site.
Thanks for all the help guys, it is a wicked truck.
BIG D
