Originally Posted by MetalMan
David, that would work perfectly. Just make sure not to use anything more than a stock motor with the 2s1p, since these cells may/may not be able to handle the amp draw.
Yay, makes me feel special that I was actually able to crunch all those numbers and not screw up at all! :027:
The main reason I was thinking stock motor is because it would have a real low amp draw, and yeild the most runtime with that pack. I wonder what the rest of the competition would do if they knew I was running Li-Ions......:005:
