Thread: BL Revo
HotnCold
HotnCold's Avatar
04.01.2005, 09:45 AM
Yeppers - RC-Monster Mikes has at least one that is in the 8 lb range with batts - I cant get my pig down below 9.4lbs lipo loaded..... As far as the wires are concerned - I used the body post off my terra crusher. It is a post on the bottom and gets bigger on top and has 3 holes in the top - which i use to individually hold each wire - I just drilled a hole in the chassis where i needed the support post - pre-tapped the bottom of the post and that is that - dosent move - and no wire movement - hope this helps ya....
Hows that "Hope and Change" working out for Ya???
