MetalMan
MetalMan's Avatar
05.20.2006, 04:21 PM
They are round cells.
The specs don't look too bad. 2p would be an obvious requirement, unless you're doing some short speed runs where weight savings are wanted. These cells seem have close to the same nominal voltage as the Saphion (LiFePO4) batteries I have (3.2v). Those have a CV phase charge voltage of 3.65v, but can accept 4.20v without problems.
Hopefully the prices will go down like they have with the V28 packs, so then some of us can try them :).
