MetalMan
MetalMan's Avatar
05.21.2006, 07:35 PM
Only problem with using a volt meter is that you can't use it while your driving. Under acceleration, the voltage will draw from high amp spikes, but afterwards the voltage will come back to normal. Without a LVC, you have no way of knowing how low the voltage of the cells under load is.
