04.03.2005, 10:46 AM
Maybe you used 12 cells but put them in parallel instead of series. I don't mean to sound insulting, but I believe that with the two battery packs, you hooked up positive to positve and negative to negative. When you hook up 2 batteries to make a "12 cell pack", you're supposed to hook up the negative from one to the positive of the other so all the cells are end to end.
