05.23.2006, 09:13 PM
I'm running proline bowties or Losi Zombie Maxx tires. Both are pretty close to stock size.
As for what I'm loking for, I have 8000mah 5cell lipo setup that I am going to be running. I want something that I will be able to run for a full charge and not overheat. Id rather be a little safe than agressive, at least at first. If the initial setup works out ok I may rty stepping up the gearing to maximuze the speed, but I want to start on the safer end.
I thought that the 66/24 gearing would be ok as well from what I have read in the forums here. The main reason I asked is cuz theres not much gearing info for a 66t spur. Like you guys said most are running the strobe 51t.
So do you think the 66/24 would be ok?
