For the wheelie bar, I used steel road ends which I polished (I can mount different size rods to adjust the length), slot
car alloy rims and a heavy duty shock which I adjust in length and limited in travel with the white washers which are
usually come with every shock (just placed a couple over the shock shaft inside the shock).. now I guess It will work... but I will see
Wish me luck for the first testrun....
