Originally Posted by squeeforever
Are you running a 6S2P or 1P configuration? I would go for some backs made up of 4000mah cells in a 3S2P pack and a 2S2P pack for 8000mah.
you asked if i had 2p or 1p config. i wasn't sure so i said i think 1p? then i told you 2 3s packs so you could determine 1p or 2p. i'm running polyquest right now, can i get more in the config you talked about squee?
