05.30.2006, 09:56 AM
I have tried, but when i adjust the screw to give 1 mm gap, and then play with the throttle setting on the transmitter, i still have the braking problem...meaning when i brake, it stalls due to too low of an idle, so i have to run it at a high idle. Any suggestions on redoing the linkage so when i hit the brakes, it doesn't cut the motor?
thanks coolhand, sorry, new to nitro and i'm sure it doesn't help that the motor was probably beat on a little from the guy i got it from....working on rebuilding it. i have a 3.3 on the way, but can't find a clutch set up for it and am not sure about the gearing to use....
