GriffinRU
05.30.2006, 10:28 PM
Originally Posted by Serum
The size of the daughterboard doesn't matter too much, as long as it stays smaller than the big schulzes.
Or do the same thing that MGM does.
The controller board in the center and the two powerboards outside (with a heatsink)
How tall can be cube, like MGM?
I can put 2 PCB's with 12 FET's on each (both sides). With 4 FET's I hope we do not need heatsink, it would be heavy enough with all that copper from D2Pak tabs. Or we can add 3d board - 6 FET's - getting expensive ($5.00 each).
Or 2 FET's per phase and heatsink to frame? What if there is no metal frame? Electrical isolation can be done with regular heatpad.
Artur
