Thread: Brushless help
coolhandcountry
coolhandcountry's Avatar
06.03.2006, 03:58 PM
You had a hopped up emaxx two years ago. The upgraded internals has me worried. If you got the aluminum out put shaft and input shaft. They won't hold up well under alot of power. I have been thru them. If you go cvds the ue are the best. The robinson will hold up to some force. I think the strobe is alittle better for it has the mod 1 gears. I take it you still running the stock tub chassis. How many cells are plan on runng 12 or 14? If you stick with the stock diffs the 10 L may be a good choice for it won't be to hard on the driveline. I didn't catch tire size. If big tires it will be hard on drive line anyway. I love them though myself. If you want more power you can choose a 8xl or even 7xl depending on the run time you want.
Peace!
Country
Help support the
Rc-Monster
Buy here
