tallyram
tallyram's Avatar
06.10.2006, 12:00 AM
i want to put the monster heatsink on the motor and a fan on the esc. this g2r already weighs a ton though.
edit: also, i'm having a lot of trouble finding the perfect track setup. the g2r chassis sits lower than stock, but the truck weighs more. seems like i have to use to stiff of a setup to keep from severely bottoming out when using the lowest ride height. my setup right now is 40w oil all the way around with green/fr and black/rr, using tallest ride height hole. still pretty soft on landings. should i try 50w oil and leave the springs alone or stiffen the front springs and leave the oil alone?
  Send a message via AIM to tallyram
