jhautz
jhautz's Avatar
06.11.2006, 05:55 PM
Anyone know if if the battery type setting on the Quark will make a difference? Right now I have it set to Lipo High cuz the batteries I have will handle the discharge rate. If I switch to Lipo normal will that cap the amp draw at a certain level? If so does anyone know what the cap amperage would be?
I'm not sure I'm clear what the difference between Lipoly high and Lipoly normal setting is. The documentation is pretty weak and doesn't really say what the difference is. It just cautions that the batteries should be able to handle %150 of the expected discharge if you are going to use the high setting. Anyone know?
to make it...
or break it...
Silent...But Deadly
