steve050773
06.11.2006, 07:37 PM
Alright guys -
Got to do a better test with the ESC direct soldered to the motor and there was an improvement.
On a smooth surface, I don't see any hesitation. If I go off into grass, there is still hesitation when I make any substantial stab at the throttle.
However, I did notice that reverse seems to move at a pretty good speed irregardless of the surface. Could it be that reverse has some type of program limitation on the 9920 (25% power, or 50% power) and this limits the strain I'm putting on the esc?
Next, I'm going to try and redo all of the battery connections. If that doesn't change anything then I know I'm probably down to a controller issue.
Any thoughts? Any recommendations on a better controller?
