06.12.2006, 11:32 AM
Originally Posted by MetalMan
I thought the A123 cells are smaller than Emoli cells? Emolis are 26mm x 70mm, A123 are 26650, which is 26mm x 65mm.
I assume you are referring to the spread sheet? If so, you are right. I must have switched them around for some reason (probably when I named the cells at the top). From what I've read, Emoli's are 3Ah @ 26.5mmD x 70mm @ 99g, and M1's are 2.2Ah @ 26mmD x 65mm @ 70g. I'll fix that on the sheet when I get home tonight. Sorry. :dft001:
[Edit]: Spreadsheet fixed and uploaded...
