MetalMan
MetalMan's Avatar
06.15.2006, 09:02 AM
Originally Posted by Nick
So these 8000mAh True RC ones are like 8c discharge? Is that abit low?
There is no such thing as a "low" C rate. Since these cells can handle 32amps continuously, and higher in burst, that's not too bad as long as you use a 2p setup for 8000mah and 64amps continuous.
Originally Posted by skellyo
I believe you meant to say Ah = mAh / 1000
