Thread: bk20120
harness
highflier
Emaxx- FLM wannabe
harness - 06.17.2006, 09:28 PM
I am going to do something different in the future. Probably Lipos 5s. I can just have a 3s and a 2s pack and use it like I set it up. I already have test run it. I think I need to figure a few things out yet.
1) Battery temp was 110, Motor was 130, ESC was 110. Does that sound about right. I did not think I was pushing it that hard.
2) I was suprised to see that it ran about the same as the stock setup. I thought it would be slower, Since I got a 10xl and am only running 12 cells.
3) I built the quickest easiest block off plate ever. Here is what I did.
Got a colored (Purple) disposable platic cup from (Acme 50 pack) cut the bottom out and hot clue sealed the edge, Stick on motor plate. Looks good and should be dirt proof.
4) Throttle response is good. The brake was to strong. I flipped it a few times rear over the front :)
Next better mounting for the gear. Program the ESC for the xmitter.
Highflier
