cart213
cart213's Avatar
06.19.2006, 03:30 PM
Tazz what is your lvc set to? 12 volts is a conservative lvc setting, but if you are hitting the limit with your setup, then you can set it to 10 volts, assuming the Quark has that capability. According to Emoli, the cells are safe down to 2.5 volts each.
