06.21.2006, 07:21 PM
Are you disapointed with the lack of top speed or lack of power?
More top speed... Go up one or 2 on the pinion or down 2 or 3 on the spur.
More acceleration... Go Down 1 or 2 on the Pinion - or Up 2 or 3 on the spur.
If anything stars overheating, go back a tooth or 2, you have reached the limit.
According to my calculations the setuo you are running should be around 37mph top end. If you go down to a 14 tooth, its around 33mph. Up to 17 tooth, around 40mph. Although you are probably reaching the limits at 70/17 if you can run it there without overheating.
I have a emaxx w/ the same motor and esc. I run 66/16 (Almost the same ratio as 70/17) and its about all it can take. I have to run a fan on both the motor and the esc to keep it cool. Mines pretty heavy though. It mign not be as bad if yours is lighter.
to make it...
or break it...
Silent...But Deadly
