squeeforever
squeeforever's Avatar
06.22.2006, 05:09 PM
The new MRC 989 is slightly better and would allow you to charge them in series at 4 amps or however you see fit. As for balancers....thats a pretty good balancer already. There are however, modifications you can do to charge/balance at the same time, in line, at a higher amperage since it heats up charging at higher amperages.
