06.22.2006, 08:30 PM
The current draw will be very low. About 10 amps average and 25 amps continuous at full throttle. I don't think it will pull more than 60 amp spikes. The 13t is a pretty efficient motor. I was thinking you could run 20c 2100 or 2500 cells w/ 15 minute runtimes or a max amps 12c 4000 for 25 minutes. Check the dimensions to make sure they will fit in the battery tray.
