06.24.2006, 07:38 AM
Tahnks brian. I wanted to know if a motor like the xl1200 and xl12 turn both spin about 1200 kv give or take 51. :D One motor is rated at 55 amp the other at 26. I was wonder if they would produce the same amount of torque on the same amount of amps or would the xl12turn produce motor for it has more rotor area. If that is the case I should possible get more run time out the xl12turn than xl1200.
By looking at what you explained. If i go up on voltage the watts will go up and the torque as well. So If I pack a 8s lipo on instead of 6s with a lower kv( higher resistance) I can get the sam torque with the same rpm with lower amp draw. Am I on the right track?
Peace!
Country
Help support the
Rc-Monster
Buy here
