06.25.2006, 12:55 AM
Brian G hit it on the nose. I run a 10xl though with 16 ib3800's and get about 28 min, thats bashing, but i put a lot of top speed on that most of the time. If you want to keep up with the 3.3, GO LIPO! You lose tons of weight, also, dump four shocks and first gear, so you may as well do the conversion to single speed. It cuts you tranny in half! Steel idler a must! CVDS, MIP or UE are great. Remember, Nitro generally is already lighter, so the more cells you run, the more weight you add, the more weight you add, means less speed and could mean more damgage when you crash. Also, in my opinion, get better than the 9920....20120 maybe? Depends on the motor...I personally would get a lehner....
Squee, calculator...grearing?
