Originally Posted by squeeforever
If the cells are 5C cells then a 2P pack would be 10C. If 5C is 40 amps cont. then 10C will be 80. The packs are really cheap but really good. The owner is a GREAT guy to.
The c rating don't change when you parrellal the cells. It has a higher amp draw for it has more mah.
