Procharged5.0
Procharged5.0's Avatar
06.27.2006, 01:09 PM
So using the Emoli's with the Quark Monster 125b I should assemble a pack with five Emoli's instead of seven due to the voltage capacity of the Quark?
Considering (2) separate 5S packs to be used in parallel producing ~ 6000 MAH.
Also, it appears that the emoli's are significantly longer than the std sub-c nicad or NiMh presenting chassis fitment concerns on my FLM extended chassis supermaxx..
Lastly, what charger are you V28/Emoli guys using? Can I set the charger for 5S packs?????
Your thoughts METALMAN & SQUEE?
