neweuser
neweuser's Avatar
06.29.2006, 09:49 AM
Actually, if you can solder plugs, wires are easier, just make sure you tin them before soldering together. someone here should be able to direct you to a wiring diagram....if your talking about batt packs, you should be able to choose preassembled packs or loose cells....
