Need help on different saver -
07.01.2006, 04:46 AM
I need to use a different servo saver on my flamemaxx chassis than the normal one(the 2 arm's are in-line with eachother) I need the saver part to be like a crt saver, so the 2 arm's have an angle of 90 degrees.
If any of you know a saver that fit's the maxx ( 4 cm's high and both arm's from center to center 2 cm's) please share.
Thank's in advance.
