sforsancho
empty wallet
sforsancho's Avatar
04.14.2005, 12:07 PM
Originally posted by Strobe
My necks are about .02 larger in diameter and a larger radius in the corner
The thread is not tapered but...
They've been tested in the Revo and are doing extremely well. They pretty much conform to all pillowball specs to a degree. The shank diameter is larger and a few other changes. The larger dia had no effect on range of motion in the Revo.
They should install OK for you, watch to make sure they easily thread into the arms if you decide to try them.
I just checked them in a set of Racer-X arms I have and they got pretty tight when threaded all the way in. I would not recommend them in aluminum arms unless you have an easy fit. The minor dia on my threads is slightly larger then specs.
Straight off the UE forums. I'd buy a set but it sounds risky.
