07.04.2006, 12:04 PM
A slipper would be a must. Even with the HV. I would get the Strobe setup and Mod1 gears. One thing you would break before all else though, is the bulks. Instead of getting bulks and cases, get the FLM combos. They incorperate the cases into the bulkheads and are the strongest setup you can get. Plus, it almost works out to the same as the cases and bulks combined.
